Errors in operators task
hridoy_md_a
hridoy_md_a
[ FlexSim 19.0.9 ]
Model 4.fsmHello,
In my model, I am having errors with the operators. Operator2 is not moving much and operator1 is working more. I want both of them to work equally. And the errors check bellow-
time: 0.000000 exception: FlexScript exception: Array index out of bounds at MODEL:/Operator2>variables/onresourceavailable
time: 0.191809 exception: FlexScript exception: Array index out of bounds at MODEL:/Operator1>variables/onresourceavailable
time: 18.274490 exception: FlexScript exception: Array index out of bounds at MODEL:/Operator1>variables/onresourceavailable
time: 34.680520 exception: FlexScript exception: Array index out of bounds at MODEL:/Operator1>variables/onresourceavailable
joerg_vogel_HsH
Travel to Home object on Resource gets available trigger: Please select current and NOT
current.inObjects[1]
You want that the operator himself goes home and not that the dispatcher does it.
hridoy_md_a
Thank you so much. It is working perfectly.
