Error when opening animation
maira_a
maira_a
[ FlexSim 21.1.0 ]
I need to do more animations in my model, but always that i open the option edit - "animations" my file have an error and close some minutes after. Can you help me?
File_here
moehlmann_fe
There are some nodes in the view tree, that were not corretly deleted when closing their respective windows, that are causing this. If you delete them manually the model should function properly again.
(Delete by selecting the node and hitting the "del" key)
maira_a
@Felix Möhlmann thank you so much! This solution is what i needed. Can you explain me how did you find the problem in this specifics nodes?
moehlmann_fe
There was a question with a similar problem (flypath window wouldn't open) around 3 weeks ago. When I tried to open the console window to try and debug the model it wouldn't open. After some searching I found that the view node(s) of that window were still in tree. So I tried deleting them and that worked.
Since your problem was very similar I though it might have the same cause.
maira_a
Understood! Thank you for your help.
edmilson_ml
I have a similar problem, in my case the animation does not open and close the program. I already did the above procedure, but it didn't work.
jason_lightfoot_adsk
Have you tried opening the Default Workspace?
