Error saving file with Flexsim 2021.2.1
tee_hiett
tee_hiett
[ FlexSim 21.1.0 ]
2021 Covid-19-Hoover-Met_10.fsm
The attached model was created with version 2021.0 .2. I opened it with the 2021.1.0 version and it seems to run fine. But when I saved it I got the attached error message and the saved file size is 11,859 kB as compared to 568 kB in the original file.
Tee
Ben_WilsonADSK
@Tee Hiett,
Can you post the original, non-upgraded file? That will help us to figure out what happened during the upgrade.
Hopefully you followed the suggestion to save the upgraded model under a different name, or have a backup solution like CrashPlan or BackBlaze that does file versioning.
tee_hiett
2021 Covid-19-Hoover-Met_8.fsm
Sorry about not sending the prior version model.
Tee
Ben_WilsonADSK
Hi @Tee Hiett,
I opened your model in 21.0.3 without problem. For good measure I opened the default workspace from View > Open Default Workspace, then saved again in version 21.0.
Then in a new installation of the 21.1 beta I opened that model.
It seems to have opened and upgraded just fine. The file size is the same as the original. It seems to run fine.
I've attached the version 21.1 model here:
2021-covid-19-hoover-met-8__21.1beta.fsm
