Error message resolution
a9080109
Message 1 of 19
a9080109
I don't know why my model has this problem. It shows that there is a problem with unload, but I don't know why this error occurs!!
Replies (18)
Message 2 of 19
a9080109
@moehlmann_fe Hello, do you know anything about this topic?
Thank you.
Message 3 of 19
FelixMoehlmann
The "tote" label on the parent token gets overwritten with the puller in the Push to List activity shown belong. It then points to a token which can't be unloaded, so the other child token can't finish its task sequence.
Message 4 of 19
a9080109
I think I have solved it?? But there are similar situations later, but I can't solve it in the same way
Message 5 of 19
a9080109
@FelixMoehlmann  i want to ask i need to do this logic in my model! i need to check always have two empty tote in each buffer! but  my logic didnt work!! why~~
Message 6 of 19
FelixMoehlmann
Different errors will of course require different solutions. The general debugging flow stays the same though. If you get similar error messages then look at what value is missing (in the error in your question it's the item to unload). Then search for the respective and check which label is missing or has a wrong value. Then you can try to find why that is the cause.
For anybody to be able to help you with the buffers, it would be useful if you could show where the relevant logic is positioned in your Process Flow, since it's very large, mostly copy pasted and thus very hard to deduce what is happening where.
Message 7 of 19
a9080109
Yes of course I try to know my loss number but this time I don’t know why happening this number say I unload empty tote to Q and later error happen!
Message 8 of 19
a9080109
I should have solved the problem of loading and unloading goods by now?? (I should)
But now when I travel, I often encounter the problem that my rack will become an id. I tried to check the list all or nothing but it didn't work!! I want to know what happened and how to solve it
Message 9 of 19
FelixMoehlmann
I think the main issue in your model is that you create very complex "families" of tokens. See the example screenshot below showing the parent-child relationships of a token chain. There are child-token of different generation in the same activity which means you probably have loops in the overall cycle. With that many relationships and label access on parents it becomes very tough to follow what repercussions label assignments might have. Assigning a label to some token might also change the value its "great parent's second degree nephew"-token can access, if you understand what I mean.
As it stands, I understand why you are having difficulties to debug the model, but so would anybody else. So my suggestion would be that you rethink how tokens are created. For example, I don't see why you would create a child-token right before a token enters a sink. If the token is no longer needed, the created token should probably be independent (with necessary labels copied over) or even just move the token to other part of Process Flow instead of creating a new one.
Message 10 of 19
a9080109
My understanding is that after I have done this, I need to be notified that I should do the next stage, so I created a token to allow the whole process to proceed. So what do you suggest is where should I start to make changes? Should I start from the beginning?
Message 11 of 19
FelixMoehlmann
As I said, I think the first step would be to create independent tokens instead of child token where possible (meaning where the parent is not waiting for the child to finish some process or vice versa)
Message 12 of 19
a9080109
HI Feilx  I think I should improve the token creation problem, but there are still some problems with my model that need to be solved
Question1 :Why can't my item be moved? It keeps getting stuck in the task creation process but no error message is generated. However, my other machine has no problem?
I want to know why the usage rate of my machine is so low! I feel very busy or I spend too much time waiting for the car or something like that
Message 13 of 19
FelixMoehlmann
You don't see an error message because the views in the model got corrupted (probably a window that is stuck open but not actually visible). Use "Open Default Workspace" under "View" to rectify this. Then you should see an error message that tells you that a bad task executer reference is used in the Create TS activity. Somehow a token ends up on the RGV list at around 4600s into the model (compare model time and age of entry). Check what is getting pushed at that time and where to hopefully find the issue.
There are four processors with a process time of 30s. That means a vehicle would need to arrive in that area of the model at least every 10s in order to achieve a decent utilization. I don't see how that would be possible with distances of hundreds of meters with this number of vehicles.
Message 14 of 19
a9080109
I want to know in what situations will I need to check the option of keep on list, what difference will it make? In my model, do I need to check it if I need to push the agv back?
What is the difference between the two models?
Message 15 of 19
FelixMoehlmann
If the box is not checked, the token and pushed value are linked. When the token exits the Push to List activity, the pushed value is also removed from the list. If you want the token to continue (Max Wait Timer) while making the AGV available on the list again, "Keep On List On Early Release" should be checked, so the value stays on the list when the token continues.
Message 16 of 19
a9080109
So it sounds like I want rgv to work again. Should I check this?
Message 17 of 19
FelixMoehlmann
Yes, it should be checked.
Message 18 of 19
a9080109
@ moehlmann_fe
I want to write a new version of the taxi-calling process! But I found a very strange problem. Why does it always say /TaskExecuter1 when I call an empty box? But I observe that it does not execute the task immediately? I don't know why this happens?? Can you help me?
Message 19 of 19
a9080109
I also found a problem, why my ball3/4 tasks are executed very late, I observed that my car was not towed away and was stuck in the create ts task (all /TaskExecuter1)
Normally, shouldn't it be possi
ble to execute tasks as long as it pulls a car? Why does my/TaskExecuter1 execute several tasks?
