Error message in Compiler Console -- invalid character ascii=-1
tee_hiett
tee_hiett
[ FlexSim HC 5.1.0 ]
Flexscript Error VIEW:/active/MainPanel/BackPanel/SplitterXPane/QuickProperties/ToolPanel/Views>eventfunctions/showPanel line 1 invalid character <ÿ> ascii = -1 Flexscript Error VIEW:/active/MainPanel/BackPanel/SplitterXPane/QuickProperties/ToolPanel/Views>eventfunctions/showPanel line 2 syntax error, unexpected end of code, expecting ';' check for the proper number of parentheses/braces Could not finish parsing because of previous errors.
Matthew_Gillespie
There's something in your view that's been corrupted. All you need to do is refresh the UI.
From the View menu select the Open Default Workspace option.
Matthew Gillespie
FlexSim Software Developer
tee_hiett
Thanks, that solved my problem.
Tee
