Error Message by building DLL
sebastian_kemper
sebastian_kemper
[ FlexSim 7.5.4 ]
I want to start building module DLL with Visual Studio 2012. I downloaded the flexsim-module-sdk from bitbucket.org and do the FlexSim-Wizard-Installation. After this I try to do the MyTaskExecuter Tutorial, like it is discribed in the ModuleDevelopment Documentation html.
My Problem is, that I get 353 Errors because of the FlexSim Header Files, as you can see in this screenshot:
I don't know what's wrong?!
matt_long
I assume you followed all of the steps in the Documentation/QuickStart.html file?
ralf_gruber
Hello Sebastian,
did you download the correct version of the SDK from Bitbucket? In the downloads section on bitbucket you'll find an SDK for each FlexSim release and you need to match it to the FlexSim version you use.
If this doesn't solve it I'll have to pass it to @phil.bobo
Good luck
Ralf
sebastian_kemper
Hello @Ralf Gruber,
in the file I downloaded, there are 4 different release (VisualStudioWizards_2010, 2012, 2013 and 2015)
So when I use Visual Studio 2012, I have to install the VisualStudioWizards_2012, or not?
Does it than matter which FlexSim Version I use?
I want to use FlexSim7.5.
Kind regards,
Sebastian
sebastian_kemper
Hello Ralph,
you are right, I used the wrong FlexSim SDK, Steven Hamoen already helped me.
Have a nice weekend!
ralf_gruber
@Sebastian Kemper
You need to download the SDK that matches your FlexSim version. Each SDK supports different Visual Studio versions, but is compiled for one specific FlexSim version.
Does this help?
