Error message appears only when debugging code
tatiane_giro
tatiane_giro
[ FlexSim 22.1.2 ]
I'm simulating a model using the storage system. I want to search for an item according to its "SKU" label. I put in my query, in addition to the matching of the SKU label, one more condition for search this for aisle, because I want to know what aisle has the most number of itens and also has the SKU that I want, that is, I want to take the item from the fullest aisle.
When I reset and run my test model (without debugging the code), it works correctly. It doesn't show any errors.
However, when I debug in the Process Flow the "Assign Labels: Corredor" activity, the first time it checks each aisle it appears an error. Then, it no longer appears.
This error appears and happens only at debug time. Could this be a bug?
The model is attached.
testerack3.fsm
philboboADSK
We fixed an issue with debugging Table.query() in 22.1.2. This seems to be a related bug with debugging Storage.system.queryItems(). I'll add a case to the dev list.
Thanks.
Phil BoBo
Sr. Manager, Software Development
