Error In the model
Error In the model
b_turostowski
Error In the model
b_turostowski
[ FlexSim 22.0.16 ]
Hello
I opened the model that have been created long time ago (2015 was opened last time) and I wanted to use a model, however I had plenty of errors when the model run. I fixed some of them, however I have one I cannot find the root cause. See below messages I have in console:
time: 2050.016088 exception: Exception Caught in FixedResource::getItemInfo(treenode flowitem)
time: 2050.016088 exception: Exception Caught in FixedResource::getItemState(treenode flowitem)
time: 2050.016088 exception: Exception Caught in getitemstate(treenode item)
time: 2050.016088 exception: Exception Caught in ObjectFunction114__project_exec_commandlist_getitemstate_node object: MAIN:/project/exec/commandlist/getitemstate/node i: MAIN:/project/exec/commandlist/getitemstate/node class: MAIN:/project/exec/commandlist/getitemstate/node
time: 2050.016088 exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... MAIN:/project/exec/commandlist/getitemstate/node c: MAIN:/project/exec/commandlist/getitemstate/node i: MAIN:/project/exec/commandlist/getitemstate/node thisClass: MAIN:/project/exec/commandlist/getitemstate/node
time: 2050.016088 exception: Exception caught in evaluation of MAIN:/project/exec/commandlist/getitemstate/node
They repeat constantly during the model run
We are using version 22.0.0 now
Please advise
Kind Regards
Blazej Turostowski
Jeanette_Fullmer
Hi @Blazej T,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
Can you post the 2015 model and the 2022 model?
Also, please reference the release notes to see any changes between versions that may contribute to your exceptions.
If your model contains sensitive information, you could first toggle your post as private using the "make private" option under your question's "gear" menu. Private questions are visible only to site moderators. You can also contact your local FlexSim distributor for phone or email help.
jason_lightfoot_adsk
Hi @Blazej T,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
b_turostowski
Hi Jason
I am in touch with local FlexSim distributor and we agreed to try to open and work with model on the older version of FlexSim (7.7.4). I will try to do that in next few days as I had a problem with our IT to download and install the old version and try to work with model using it. This IT issue should be fixed now. I will let you know if it worked well for me in a couple of days
How did it go?
b_turostowski
Hello
Sorry have been busy with customer visit in last few days. I was able to download and install 7.7.4 version and I was able to run the model with it without any issues.
