Error for missing value in table when it exists.
gudapatisriharisha
gudapatisriharisha
[ FlexSim 22.2.0 ]
I am getting the following error. "time: 5.000000 exception: FlexScript exception: no row found for key 5 in col 1 at MODEL:/Tools/ProcessFlow/ProcessFlow/ Record Qty M3_ABC sent to Cust_ Col_ 7>variables/codeNode". A token is writing a value to a global table by reading the row value from a label and checking if the row value exists or not. If it exists, then it enters the value else it creates a row and enters the value. However, it does neither in the code. It keeps giving me this error. I ran the entire model last night and didn't have any errors when I ran it multiple times fior fixing any errors. However, today it started throwing this error when I didn't make any changes in the model.Any suggestions would help. Thank you.
moehlmann_fe
Can you show the relevant code and maybe a screenshot of the table at the time when the error occurs?
As a side note: It sounds like you could just use a Statistics Collector in place of a global table. It would do the check for an existing row by itself.
gudapatisriharisha
Hello, I fixed the error. I created the table again due to another error so now the execution in the tree was first the row calling and then the table creation. Since, Flexsim follows a hierarchy, it gave me that error. Thank you.
moehlmann_fe
Happy to hear that. Feel free to change your comment into an answer and accept it, so other can see that the issue has been resolved.
