Error about convert command: _mkgmtime64 failure
xucq
xucq
[ FlexSim 17.0.1 ]
When I use the "convert" command, "exception: Invalid convert command: _mkgmtime64 failure" displayed on the system console ,I tried many times to find where the error happened ,but it didn't work. Plesase help me with my problem,thank u very much.
mischa_spelt
Unfortunately the image is broken, can you fix that or copy/paste the convert command you are trying to execute please?
Other information that may be relevant: are you using a 32-bit or 64-bit version of FlexSim 17.0.1? Which date are you trying to convert, are you maybe expecting the result to end up after 1 Jan 2038?
Possibly this was a bug that has already been fixed, have you tried upgrading to 17.0.5?
Ben_WilsonADSK
@xu chunqi, even though this interface lets you paste in images, they will not actually be saved to the post. Make sure instead that you use the Insert Image button:
xucq
Thanks for your attention, I found where the error happen. I wrote a nonexistent parameter in the "convert" command.
xucq
I will take care of it next time.Thank u .
