[ FlexSim 22.0.1 ]
If you follow the next steps, you will notice a problem in the End of replication trigger:
- Run the experiment
- Change the code in the On End of replication trigger
- Delete the result files
- Check the code in the end of replication trigger
In step 4 you will notice that the code change from step 2 is undone. It almost looks like you press Ctrl + Z when pressing the delete results file button. Would it be possible to fix this bug?
Below a gif that shows the problem.
Patrick
