Elevator rules setting
mail7WJMZ
mail7WJMZ
[ FlexSim 20.1.0 ]
Purpose:
After the operator decides, go to the designated elevator.
Example:
Type the item labeled 1 to go to the right elevator.
Type the item labeled 2 to go to the left elevator.
The elevator group triggered the rule, but the operator performed incorrectly.
The operator cannot reach the correct elevator group.
The same model project version 19.2 executed correctly.
Matthew_Gillespie
If you open the 19.2 model in 20.0 you'll see that the model is still working in 20.0.
In the 20.0 model the divider around ElevatorBank1 is too close to the front of the elevator and so doesn't block anyone from getting on the elevator. If you move the divider out a bit further from the elevator then your model works as intended.
elevator20-fixed.fsm
Matthew Gillespie
FlexSim Software Developer
