Dynamically changing the link of a dashboard/GUI table?
gina_lasure1
gina_lasure1
[ FlexSim 16.2.1 ]
I am displaying data on a dashboard with a table. I have several tables that the user might need to view, and I'd like to be able to switch between them via a drop-down list, so that the table itself will change instead of needing multiple tables or multiple dashboards.
I found the node in the tree where the objectfocus of the Dashboard Table is saved, but changing the string there has no effect. (It just gets overwritten by whatever is in the "Link" section of the Quick Properties.)
Any suggestions?
jing_chen
Hi, Gina
Try to change the viewfoucs attribute of table(can use setnodestr()). Here is a sample
change-viewfocusv16.fsm
