Dynamically change lift speed of ASRS
sigmped
sigmped
[ FlexSim 22.1.4 ]
I want to dynamically change the Lift Speed of my ASRS depending on whether it is loaded or unloaded. I found multiple posts on changing the speed of task executioners, but only in the x and y axis. I only want to change the Lift Speed in the z axis.
Is there an easy way to change lift speed dynamically in the process flow?
Thanks in advance.
jason_lightfootVL7B4
If you open a property table for the object you will see the property names. In this case the syntax should be:
myASRS.setProperty("LiftSpeed",2);
