Dynamic travelling salesman problem
osama_a6
Message 1 of 12
osama_a6
[ FlexSim 21.2.3 ]
Let's assume that I have a truck going to different cities. For instant, let's assume I have only 2 cities (which are A and B). I want to make a table, that is linked to the truck. The table has 3 columns and dynamic rows. The column is: From, to, and time. The rows are created only when I visit the city. So, the first row is created when I went from origin A and sunk at depot B. The table will be filled as follows:
From I To I Time
1 : 2 : 3:00
I don't care about how the table looks, it is just only an example. Then; if I went back to point A from B the table will be as follows:
From I To I Time
1 : 2 : 3:00
2 : 1 : 2:30
let's say I have added another city later, which is C: then if I dispatched as follows: A, C, B (where city rank are A:1, B:2, C:3) the new table will be as followed:
From I To I Time
1 : 2: 3:00
2 : 1 : 2:30
1 : 3: 1:00
3 : 2 : 1:20
If I return the truck from B to C then to A, the table will again be shown as follows:
From I To I Time
1 : 2: 3:00
2 : 1 : 2:30
1 : 3: 1:00
3 : 2 : 1:20
2 : 3: 0:50
3: 1: 0:45
I prefer to have a transcript to make the table if it is possible.
Replies (11)
Message 2 of 12
jason_lightfoot_adsk
Use a statistics collector. You can listen to taskexecuter events and try to interpret the task sequence to find the routes, or you can use process flow to generate the task sequence and listen to tokens at activities for which you know the lables refer to the route start and end points.
Message 3 of 12
osama_a6
Is there a way to do it by script?
Message 4 of 12
joerg_vogel_HsH
sure, you find for most events triggers in objects. Then you can fill and add values in a global table. If you store at your truck your currently active table row, you can add new values in a columns in your table.
Message 5 of 12
osama_a6
Can you please demonstrate it?
Message 6 of 12
FelixMoehlmann
Here's a simple example. In the load trigger of the operators a new row is added to the table and the "From" column is filled in using the station parameter of the trigger. Also, the row number and the start time of the travel are noted.
In the unload trigger the "To" information is added to the row and the travel time is calculate as the difference between the current time and the start time of the travel.
TravelLog.fsm
Message 7 of 12
osama_a6
Thank you so much
Message 8 of 12
osama_a6
Can you please demonstrate how did you do it? I want to use the same logic for trucks, forklifts, any transporter.
Message 9 of 12
It says in Felix's post the code is in the load and unload triggers of the operators - you would need to do the same for all your transporters to use this method.
Message 10 of 12
joerg_vogel_HsH
get number of rows in a table
https://docs.flexsim.com/en/22.0/Reference/CodingInFlexSim/FlexScriptAPIReference/Data/Table.html#Pr...
add a new row to a table, you need a row number for this
https://docs.flexsim.com/en/22.0/Reference/CodingInFlexSim/FlexScriptAPIReference/Data/Table.html#Me...
store row number in a label at Taskexecuter (operator)
write model time into a table cell
https://docs.flexsim.com/en/22.0/Reference/CodingInFlexSim/FlexScriptAPIReference/Data/Model.html#Pr...
travel finish: write time into another column of same row.
compute difference of involved columns in row.
Message 11 of 12
osama_a6
Does the table show automatically or do I need to build a new thing?
Message 12 of 12
Felix has created a Global Table called "Travels".
