Driving a Forklift in VR mode
sri_vikas_k
Message 1 of 26
sri_vikas_k
[ FlexSim 23.0.1 ]
Hi @Phil BoBo
I have watched a video in YouTube, Where the Transporter is being driven in VR mode. Can I get a demo model of it.
Please watch the link below for detailing.
https://youtu.be/_xhFXM29nIA
Replies (25)
Message 2 of 26
ralf_gruber
This model has been built by @Felix Möhlmann in Germany. But he cannot see this post because of you setting it to private.
Message 3 of 26
sri_vikas_k
Hi @Felix Möhlmann
Could you please send me the demo model.
Message 4 of 26
FelixMoehlmann
we are currently working on updating the model to work with version 23.0 and still need to test some things and update the documentation.
For now I can attach the original model build in version 20.0. I will update the post once the new version is finished.
VR_Forklift_ProSim.zip
Message 5 of 26
sri_vikas_k
Thanks for the response @Felix Möhlmann
Message 6 of 26
FelixMoehlmann
Here is the updated model for the 23.0 version. Instead of replacing the "defaultview" file, you now have to place a module folder inside the respective folder in the installation directory (which will then replace the code which was previously done by the "defaultview" file).
VR_Forklift_23_0.zip
Message 7 of 26
sri_vikas_k
Message 8 of 26
sri_vikas_k
Hi @Felix Möhlmann
When I check the model in Vive Pro I am not able to make interaction with the pommels.
Message 9 of 26
FelixMoehlmann
I don't know why this would be the case. According to the command documentation I would suspect that the grip-trigger should return either 0 or 1 and thus fulfill the conditions in the code that are set to >= 0.5 and < 0.5 for the analog input of the Rift.
Maybe try printing the stick() output to the console to check if the button presses are actually registered.
Message 10 of 26
philboboADSK
Make sure you are pushing the grip button and not the trigger button:
This model uses the grip button for interacting with the levers.
About the VIVE controllers
Phil BoBo
Sr. Manager, Software Development
Message 11 of 26
sri_vikas_k
Hi @Felix Möhlmann
Hope you are doing good.
You suggested to print the stick() output to console to check if the buttom presses are actually registered. How to do this?
I have been checking with grip trigger button only as @Phil BoBo said.
Message 12 of 26
jason_lightfoot_adsk
Run this to edit the code for the open perspective view:
applicationcommand("codeeditor", views().find("active>Documents/Perspective/1+/~>eventfunctions/TouchInput"));
Message 13 of 26
sri_vikas_k
Hi @Felix Möhlmann and @Jason Lightfoot
When I run the code touch input code window popped up.
In that window there is no grip STICK_VR_GRIP_TRIGGER was not registered.
Did I observe correct?
Message 14 of 26
Sorry - I pointed you to the usual touch input location.
You can add something similar to the following script to the user commands
  • ModelOnPreDraw,
  • getHandCollisionSphere
  • getHandGripPosition
#define LEFT 0
#define RIGHT 1
print(stick(RIGHT, STICK_VR_GRIP_TRIGGER));
Message 15 of 26
sri_vikas_k
@Jason Lightfoot
I have added those lines to the following user commands:
1. ModelOnPreDraw
2. getHandCollisionSphere
3. getHandGripPosition
Though I was not able to make interaction with the model..
Message 16 of 26
What grip trigger values are you getting?
Message 17 of 26
sri_vikas_k
When I debug it, it is showing like this for me!
Message 18 of 26
The idea behind the print statement was to press the grip and look at the output console to see what values are being registered.
Message 19 of 26
FelixMoehlmann
In order to see the valuse of print() you have to open the output console. Then press some buttons on the controllers and see if any output appears.
Message 20 of 26
sri_vikas_k
Hi @Felix Möhlmann & @Jason Lightfoot
I tried printing the values on Output console, it is coming like this from me!
I have added those lines to the following codes,
1. ModelOnPreDraw
and interacted the controllers with the stick and no value came in the output console.
