Downtime based on quantity of parts processed, specific tools, etc
julian_valdes1
Message 1 of 8
julian_valdes1
[ FlexSim 16.0.1 ]
Do you know if we can set up a processor's break time based on the number of processed parts? Like for every 500 processed parts the processor will stop for 10 min tool change.
Replies (7)
Message 2 of 8
Matthew_Gillespie
This model shows how you could do it using Process Flow.
The Wait For Event activity waits for the output of the processor to reach 5 and then the processor breaks down. After the break down the label is incremented by 5 so now the Wait For Event is waiting for the output to reach 10.
Matthew Gillespie
FlexSim Software Developer
Message 3 of 8
brenton_king
Julian,
Not sure if you have joined the Process Flow craze yet? 🙂 If not, here is an easy way to do it with the processor.
It is a picklist option in the setup field.
Message 4 of 8
julian_valdes1
Thanks a lot for both answers; still not clear how Flexsim manage something like CNC machines tool changes: one CNC has upto 12 cutting tools, each tool has a specific tool life and tool change time (setup time):
tool#1: change every 200 pc & it takes 300 sec setup
Tool#2: 500 pc / 150 sec setup
Etc.....
Message 5 of 8
jeff_nordgren
This is a related question, but one that's more specific than your original question. We've moved this comment to its own question here.
Message 6 of 8
julian_valdes1
Can use the same function: "Different time for Nth Item", but on the MTBFMTTR Parameters Window? So I can set up multiple downtimes frequencies:
Every 200 processed parts (down for 4 min)
Every 500 (down for 10min)
Message 7 of 8
joerg_vogel_HsH
MTBF/MTTR is time based, you can use this method only if every absolutely every process time is the same. Then you can set the MTBF to a set of states on the "Breakdowns" tab for processing.
That works, because the a single constant process time is equal to the processed item.
please take a look at, too.
https://answers.flexsim.com/questions/22609/cnc-machine-and-tool-changes.html#answer-22614
Message 8 of 8
herwina_richelle_andres
lot-flow-1-plane-customstate-2-itemtype2.fsm
Hi @Brenton King.
I did try your suggestion in using Different Nth Time on Set-up.
I have ticked use operator(s) for set-up with a value of 1 to cater this activity. However, I am not sure if it did work. My intention is for the operator connected at port 1 be used. The Mean Units Between Assists (MUBA) is set to 2 and will be assisted for 10 minutes. Another question would be is, does this function resets for every job? Different jobs would have start at zero value then accumulate.
Also, I would be needing to set the state of Plane17 on the following events:
#define CustomState_IAA 8 --> the delay time (10 minutes)
#define CustomState_WaitForOp_IAA 9 --> if when it requested for the operator and the operator can not attend to it yet
By the way, is the process flow function available in 7.5.2?
Thanks a lot!
