double qty generated after a combiner
yoni_a
yoni_a
[ FlexSim 18.1.2 ]
I have two sources that goes into a combiner, each source generates (item type 1 and item type 1) and then to a processor where it is processed as a single unit, then I have a separator so each item type goes to two different queues, the logic is that for 1 unit processed 2 items are split after the separator
joshua_s
Can you upload a model so we can see the problem?
jeff_nordgren
@yoni A,
Attached is a sample model that does what I believe you are asking. Take a look at the model and see if this solution would fit your needs.
The only think I did "out of the ordinary" is to modify the code in the OnEntry trigger of Combiner1 so that the green flowitem (From Source2) is placed inside of the red flowitem, so they appear as one flowitem. And that was all the code I added. If this is not what you need, please give us more details about what you need the model to do.
Thanks.
yoni-sample-jn1.fsm
yoni_a
thanks It works @Jeff Nordgren
