Does the "On State Change" event listen to all profiles ?
leah_r
leah_r
[ FlexSim 22.1.0 ]
Does the "On State Change" event listen to all profiles in a StatisticsCollector ?
JordanLJohnson
As far as I know, it only listens to state changes caused by object.setState() or the setstate() command. So for objects with multiple profiles that are built in, like the Multiprocessor, On State Change fires for the regular state profile, as well as the process profile. But if you add a custom state profile, and change it's value directly through the TrackedVariable API, then On State Change won't be fired.
Jordan Johnson
Principal Software Engineer
kavika_faleumu
Hi @Leah R, was Jordan Johnson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
