Do I have to press the plus button multiple times?
__ANON_USER__1
__ANON_USER__1
[ FlexSim 19.0.9 ]
About Experiment Tool.
I made 100 scenarios of 100 variables.
I have saved it in an Excel spreadsheet.
To write a scenario in the Experiment tool,
Do I have to press the plus button 100 times and 100 times?
Or
Is there a way to increase the total to 100 rows and 100 columns?
Ben_WilsonADSK
Hi anonymous user, was joerg.vogel's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept or comment back to reopen your question.
mischa_spelt
It is possible to get this done with a smart Excel Import and a little bit of scripting. I have attached a sample model for FlexSim 20.2, in which I did the following.
1. I reproduced your Excel workbook: ScenariosVariables.xlsx
2. I created an Excel Import to import the workbook into /Tools/Experimenter/ExperimentVariables. To get all the data, I had to check "Use Row Headers" and "Use Column Headers" and explicitly specify starting and total values:
3. I checked "Execute Post Import Code" and then clicked the "Post Import Code" button to add a bit of script, that will get the table in the exact form the Experimenter expects. This is what I put there:
int onreset = param(1); //1 if this code is being called on Reset of the model, 0 otherwise
treenode target = model.find("/Tools/Experimenter/ExperimentVariables");
// Set the number of scenarios
model.find("/Tools/Experimenter/NumberOfScenarios").value = target.first.subnodes.length - 1;
for(treenode variable = target.first; variable; variable = variable.next)
    // Variable should be an Object
    variable.dataType = DATATYPE_OBJECT;
    for(int i = 1; i <= variable.subnodes.length; i++)
        if(i == 1) {
            // The first node, pointing to the data, should be called variable
            variable.subnodes.name = "Variable";
        } else {
            // Make sure the subsequent nodes have string datatype
            Variant value = variable.subnodes.value;
            variable.subnodes.dataType = DATATYPE_STRING;
            variable.subnodes.value = value.join("");
            // For aesthetic reasons, copy the scenario name from the first variable, too.
            variable.subnodes.name = target.first.subnodes.name;
4. Run the Excel import.
5. Profit.
Here is a complete demo model for 20.2.
