DLL connection problem
jamesbomd006
jamesbomd006
[ FlexSim 21.0.10 ]
I type the dll connect function bust still have error
jason_lightfootVL7B4
Make sure the dll file is in the correct location - put the full path if needed.
jamesbomd006
I am sure my dll is in the correct location
Jeanette_Fullmer
Hello @王,
Is your DLL standalone or in a module? Where do you have your DLL located? Can you share your DLL with us so we can test it?
Jeanette_Fullmer
Hi @王 ,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
jamesbomd006
I have solve the problem thank you for your help.
kavika_faleumu
If you don't mind, could you please provide your solution as an "Answer" here? This would help users in the future if they have a similar problem. Thank you!
