Displaying label in dashboard
dvajda
dvajda
[ FlexSim 24.1.0 ]
I have a label which is initiated at simulation start and then changes its value during simulation. I would like to view value of the label in dashboard, however I'm getting Invalid ID error. 1712738021495.pngzavrnitev4.fsm
FelixMoehlmann
For the chart to work the label has to exist when the model is reset, so the Statistics Collector for the chart can correctly bind to it.
Just create the label on the rack while the model is reset (and re-select the label in the chart properties). You could then also use the "Automatically Reset" option, so you don't need the trigger to set them to 0 anymore.
dvajda
Thank you, that solved the problem.
