Dispatching two operators from queue to 2 processors
hf_96
hf_96
[ FlexSim 19.0.0 ]
Hi, I would like to dispatch 2 operators from one processor to two following identical processors that perform the same task.
Dispatch.fsm
Thank you in advance for the help.
Jeanette_Fullmer
Hello @Hi C,
Place a dispatcher in the model. Center port connect the queue and processors to the dispatcher. Then connect the dispatcher to the operators (The direction matters). Nothing else should be connected to the operators.
Make sure you have "Use Transport" or "Use Operators" selected where you want it.
