Disappearance of materials when importing Solid Edge file
inigo_g2
inigo_g2
[ FlexSim 22.0.0 ]
I am trying different software to create simulations of production lines and with FlexSim when importing the models, the materials are not imported and the models are displayed with only one colour. The file type in which the models are exported is .stl from Solid Edge.
philboboADSK
The stl format doesn't contain material information. Try exporting to a 3D format that includes material information, such as jt.
Phil BoBo
Sr. Manager, Software Development
gologur_tree
I had the same problem with different file formats. Now I use the software AC3D to colorize and edit the files in before loading in FlexSim. Perfect tool. There you can export the file as .ac format. FlexSim can handle .ac perfectly. Highly recommed using AC3D.
https://docs.flexsim.com/en/19.0/Using3DObjects/CreatingCustomObjectsAnimations/CreatingCustomObject...
https://www.inivis.com/
connor_a
Hi @Igor, was one of Phil BoBo's or Bach's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
inigo_g2
Thanks!! I will try it.
inigo_g2
I tried it but the file was not visible.
philboboADSK
From that image, it looks like the importer at least read the size of the shape properly. We might be able to figure out whether the issue is on the export side or the import side if you attach the jt file itself.
Try changing different settings in the Solid Edge to JT Translation Options window in Solid Edge.
We can't tell what you are doing or what's wrong unless you provide more information.
You may need to use a 3rd party converter such as PolyTrans if none of Solid Edge's export options create files with the data you want.
Phil BoBo
