Disable ASRS initial lift height
steven_chen1
steven_chen1
[ FlexSim 18.2.2 ]
In properties of ASRS, there is an option called Initial Lift Height. On ASRS finished a task it will move lift to the specific height.
Can I disable the feature to make the ASRS maintains its height after unload?
If not I think I have to use BasicTE to build my own ASRS. Hope one day I can copy the build-in objects as BasicTE and modify its code, so I don't have to make one from empty object.
philboboADSK
You can try to fight against the ASRS's built-in kinematics by manually adjusting them with code (shown below) after performing an offset travel operation, but using a BasicTE would be better and easier if you want custom behavior that is different from the current ASRS behavior.
treenode forkkinematics = getvarnode(token.ASRS, "forkkinematics");
double extenderloc = getkinematics(forkkinematics, KINEMATIC_Y, 0, time());
double forkheight = getkinematics(forkkinematics, KINEMATIC_Z, 0, time());
initkinematics(forkkinematics, 0, extenderloc, forkheight, 0,0,0, KINEMATIC_DO_NOT_PRUNE);
Phil BoBo
Sr. Manager, Software Development
ckruppU5CNT
Hi @Steven Chen , I know it has been a long time since you wrote this question, but I had the same problem, and I eventually found a solution which might help others.
Instead of switching off the automatic "return to home" tendency of the ASRS vehicle, I tricked it into thinking that the current level is it's "home" position.
I put the following custom code snippet in after each unload activity: (My ASRS vehicle is representing a shuttle in this case, token.shuttle.)
Object shuttle = token.shuttle;
double newlevel = 26 + (token.T_level-1)* 90.0;
shuttle.setProperty("InitialLiftHeight", newlevel);
This makes the ASRS vehicle stay at it's current location while idle.
I hope this helps anyone searching for the same solution.
