Disable adding objects and UI
tomas_heflerLXV8L
tomas_heflerLXV8L
Hi all,
is it possible to disable adding new 3D objects in certain model, to prevent unwanted modifications? (I know about restricted model, but that doesn't prevent adding new objects)
And is there some way to turn off double click dialog windows of adding object or modifying properties in 3D model, like the one in picture below?
Thanks for your advice
Ihor_Radikhovskyi
Hi, @tomas_heflerLXV8L
Have you tried creating a custom GUI for this? It might be possible to hide the object library and prevent unwanted changes. The double-click behavior would need to be checked separately.
tomas_heflerLXV8L
thanks for your answer, you're right with the GUI idea as that should be a good way. It's just that this model I'm working on something like a demo model to show possible customers and I want to keep the original FlexSim UI, with process flow, properties bar, dashboards and all the stuff which would leave me with recreating it all in GUI form.
