Destination when using a group of queues
alejandra_n2
alejandra_n2
[ FlexSim 17.2.2 ]
Need help figuring out why the model is not working when trying to distribute the items from a group of queues called "queues1"to a group of queues called " queues2" . It pulls only from one queue that belongs to a group "queue1" and then it stops when only fulfilling one queue of group "queues2"
Matthew_Gillespie
In the Pull From List activity, if you change the Request Number from 10 to 1 then the items make it to the correct queues. However, this makes the operator only carry one box at a time when moving between the first set of queues and the second. If you want to make the model work and let the staff carry more than one box you'll need to change up the Process Flow a little. Right now you have one token per box, but you'd need to change this to one token per queue or per itemtype, etc.
Matthew Gillespie
FlexSim Software Developer
Jacob_Gillespie
It works if you add a #2 path for the max wait timer that releases resource 2.
See the attached edited model.
sam-sample-2-edit.fsm
alejandra_n2
@Jacob Gillespie Thank you!
