Denoiser installation in FS2023
craig_dickson
craig_dickson
[ FlexSim 23.0.0 ]
I have been dabbling with RTX mode in version 2022 now that I have a graphics card to support it. I installed FlexSim 2023 this morning, and I get this message when I try to use it.
I confirmed that the optix file is in the folder it specifies, and I also put it in Program files/FlexSim 2023/program/nv, as suggested in the earlier forum posts.
Two things I noticed:
  • In the error popup is that the last slash / in the address is actually a backslash \ (different from the others)
  • The zip file cannot be opened by Windows, as if it's corrupted.
Any idea what I am doing wrong?
jason_lightfootVL7B4
I confirmed this problem - I'll report it.
You can get the denoiser from your account's download section under "Links" and place the extracted files in the folder you mentioned. The correct zip should be around 249MB.
Ben_WilsonADSK
In-software Optix Denoiser download+install is now fixed.
Thanks for reporting the issue.
craig_dickson
Thanks, that did the trick
