Deleting row and sorting based on column value in global table
anggoro_p
anggoro_p
I need to delete some rows that have column value <= 0 and then sort ascending the remaining rows. I am using custom code on reset trigger. My code is as follows, but it doesn't seem to work. I think j parameter on deletetablerow means number of rows that will be deleted.
Anyone has an idea?
int j;
int k;
for (k = 1; k <= 28; k +=1);
    int delRow = 0;
    for (j = 1; j < 29; j += 1)
        if (Table("ScheduledPicking_CO")["PickingTime"]<=0)
            delRow = 1;
            break;
    if (delRow = 1);
        deletetablerow("ScheduledPicking_CO",j);
anggoro_p
raja_sekaran
Hi @Anggoro P
I attached the sample model. deleterow-support-1.fsm
Use the below code to update the global table the way you wanted. I hope this helps you.
Table table = Table("GlobalTable1");
for (int j = 1; j <= table.numRows; j++)
    if (table[1] <= 0)
        table.deleteRow(j);
        j--;
table.sort(1);
anggoro_p
Hi @Raja Sekaran
Yes it works. Thanks!
However. I got another problem regarding the next reset. Because the content of current table that I resized and sorted is from another table that always has 28 rows, I can't do reset again after delete rows.
Update: I think I change the strategy. Please don't answer this question. Thanks
