Delete Global Table using custom code
brendon_n
Message 1 of 8
brendon_n
[ FlexSim 18.2.1 ]
Is there a way you can delete an entire global table using a custom code block?
Replies (7)
Message 2 of 8
raja_sekaran
@Brendon N
Have you tried using the destroy command to delete the node?
Message 3 of 8
joerg_vogel_HsH
model().find("Tools/GlobalTables/GlobalTable1").destroy();
Message 4 of 8
brendon_n
@Raja Sekaran @Jörg Vogel Yes this worked, thank you very much!
Message 5 of 8
brendon_n
Thanks to @Raja Sekaran and @Jörg Vogel
Message 6 of 8
Chukiat
May I ask more by use this topic
If I just want to clear data in Globaltable to blank but still need to keep that table with no. of column and row
What code can I use for this
Thank you very much
Message 7 of 8
moehlmann_fe
For the most part Table("tableName").clear() will be sufficient for this.
If the cells contain simple data type (arrays) or bundle data, some more code is necessary. You can just look at the code the "Clear All Cell Data" option in the global table reset trigger uses.
Message 8 of 8
Chukiat
Hi Felix
I can use Table("tableName").clear()
Thank you very much
