Delay time equal to wait for event
leandroom
leandroom
[ FlexSim 24.1.0 ]
In my process flow i got a Event-triggered source that waits for a token of the main flow to enter on a sub flow, so as soon as the event-triggered source creates the token, i need this created token stay on a delay block till the token of the main flow exits the sub flow.
How do I do that?
moehlmann_fe
Observer
Observer
Is this just to set the state? Because you can do that in a Custom Code activity. Just make sure to place a "Breathe" (0s delay) between any task activity and this one. Otherwise the object will switch back to idle as part of the default state swap.
The only way to keep the token in the Delay Task would be to use a practically infinite time and release the token in a "Release Token" activity or through code later.
