Default Custom Code Understanding?
rajankur6494
rajankur6494
[ FlexSim 21.0.10 ]
Hi Team,
I would like to confirm my understanding on below parameters as defined by default in process flow custom codes:
  1. Object current = param(1);
  2. treenode activity = param(2);
  3. Token token = param(3);
  4. treenode processFlow = ownerobject(activity);
Here is the my understanding in same sequence:
1. defines object the activity is related to.
2. defines activity treenode
3. defines token flow through activity
4. defines activity treenode
I would like to hear from you in more detail to get more clarity on these points with the help of example if possible?
Thank you!
jason_lightfoot_adsk
In a general process flow, 'current' will refer to the process flow and not the involved instance object. Only in an Object Process Flow will current refer to the object instance. So:
  • current :- the instance object OR the process flow
  • activity :- the activity where this code resides
  • token :- the triggering token
  • processFlow :- the flow where the activity is located (the same as 'current' in a General Process Flow)
