Decide Process Flow
Decide Process Flow
zuleyma_d
Decide Process Flow
zuleyma_d
[ FlexSim 16.2.2 ]
Hello Everyone,
I have this model:
I created 2 subflows in order to the operator can transport the item between Queues and Processors, and they work very well; but how can I tell to the operator, that before to go to process in the second processor, he sould donwload the item from the processor1?
I attached my model.
intento-8.fsm
sebastian_hemmannE3JAU
Hey, as it looks you are mixing Standard functionality (Tasksequences picked in GUI) and Process Flow Activitys. To do this you have to know, that every Tasksequence Activity has an own Createemptytasksequence an Dispatchtasksequence command. So standard Sequences and your created PF Sequences are mixed up and do (for us) strange thinks.
As solution there are some possible ways I think:
1. Do everything you want with standard pickoptions in the GUI (completely without Processflow)
2. Do everything you want only with ProcessFlow (without the Pickoptions in GUI)
3. Create your Tasksequences in Processflow by using "Creat TS" and "Dispatch TS" Activitys to make Sequences out of your single Tasks. This might be advanced stuff 😉
zuleyma_d
Thanks @sebastian.hemmann I tried making everything only with ProcessFlow, now is working (only two times) when the operator should load the third Iteme this error appears:
This says you don´t have the right link to the Item. Please have a look into your Processflow what Item is referenced for the third round.
