Decide code where the connector value is determined
H3xod
H3xod
[ FlexSim 23.0.3 ]
I need some help in order to find the right syntax to write the code for a Decide function(process flow) .
I have successfully written the code with several conditions but i want to push back the limit a bit by being able to redirect the token item to the connector assigned to it in the Excel File, and that is where i am stuck, cant seem to have the right logic ...
Here is a sample of the Excel file i use :
IDmenuiserieNumCadreFamilleTypeCU
11Accessoire1Dormant4
16Accessoire1Ouvrant4
3089CoulissantOuvrant2
3090CoulissantDormant2
2382FrappeOuvrant3
2347FrappeDormant3
the first code i have tried for multiple conditions is this one :
Object current = param(1);
treenode activity = param(2);
Token token = param(3);
treenode processFlow = ownerobject(activity);
Variant case_val1 = token.Produit.Type;
Variant case_val2 = token.Produit.Famille;
Variant Connector = 0;
if (case_val1 == "Dormant" && case_val2 == "Coulissant")
     Connector = 2;
if (case_val1 == "Ouvrant" && case_val2 == "Coulissant")
     Connector = 3;
if (case_val1 == "Dormant" && case_val2 == "Frappe")
     Connector = 1;
if (case_val1 == "Ouvrant" && case_val2 == "Frappe")
     Connector = 2;
if (case_val1 == "Accessoire*")
     Connector = 4;
return Connector;
it works, but like i said i want to be able to use the variable defined in the data table "CU" for the connector.
Therefore i have tried this, to no avail...
for(int i=1; i<=Table("ProcessFlow/Source%").numRows; i++)
        Connector = token.Produit.CU;
        return Connector;
        return Connector;
        return Connector;
        return Connector;
        return Connector;
I will attach the fsm and xls file to the this question.
allister_wilson
It looks like the tokens going through the Decide activity all have a CU label assigned by the source :
If you want them all to go through the connector corresponding to their CU value, you can just use that label directly in the decision :
Is this the behaviour you want?
H3xod
thanks so much, i cant believe how much i have been beating around the bush :D
and just for argument's sake what would be the right syntax if i ever wanted to write it in code?
allister_wilson
You'd get the same result within a custom code field with :
return token.CU;
