I would prefer to model it only once. For the source I tried to choose as object "group: stations", but that didn't worked...
The stations are in a row like in the picture. Later it will be like a baggage carousel. Gray coloured items should stop only at one station when it's free and not at each station in series. In short, every station does the same:
1. when station free, stop grey item for some seconds (unload carrier)
2. station blocked for a amount of time, conveyor keeps running (processing outside conveyor)
3. after blocking time stop brown item for a some seconds, make it blue and resume (load carrier)
The blue item should not stop at a following station. It's finished.
The only difference between the stations would be the processing time.
The product is a wheel which moves on the carrier in a circular conveyor. It is removed by hand to do an assembly step outside the conveyor. When assembly is finished it comes back on a random empty carrier. Later the finished wheel will leave the circular conveyor.
I agree that it would be nicer to see the wheel lying on the carrier.
But as a flexsim beginner I haven't yet achieved the ability to do that.
For testing different process times or amount of stations the workaround with coloured items would be sufficient for me.
