Dashboard statistics disappear
haneen_a
haneen_a
[ FlexSim 20.2.0 ]
In our dashboard, we were calculating the passengers' waiting time through zones. The problem we are facing is that the values (column Time) disappear at the end of the run.
your help would be really appreciated, thank you.
36843-dashboad.pngFianlTraditional.fsm
jason_lightfootVL7B4
You shoud just use a Base Chart Type "Table Chart" and set "PassengerWaitTimes" statistics collector as the data source.
You then get this:
haneen_a
I was trying to make it partition luggage into groups, as you can see above, 1|1,1|2,1|3,...1|6 is the first partition for passengers with a single luggage, and so on.
can I do the this with your suggested solution?
thank u,
You can add another column for bags using instance.Nrofbag as the value:
And then you can manipulate that using a calculated table.
haneen_a
THANKS Mr.Jason!
