Custom Lane Release using Gap Optimizing Merge Controller
ssrdh
ssrdh
I'm using a gap optimizing Merge controller Process flow for a 5:1 Merge. I want to add a custom condition where the last in line Slug (marked in red) always has priority release over all other slugs. The idea is if the last slug has a lot of flowitems, the merge should prioritize releasing those as they are recirculation on sorter. I'm trying to simulation Anti GridLock logic to avoid getting excessive flowitems onto the merge, so ideally if flowitems increase in the last slug, other slugs should be stopped until it is fully clear to avoid a gridlock downstream on merge.
Any thoughts on this would be appreciated!
Thanks!
FelixMoehlmann
Giving priority to a lane should be pretty straightforward: Give each lane token a priority label and order by that label first in the "Get Best Lane to Release" query and only then by the "isRoundRobinNext" expression.
Stopping ongoing releases would require a complete redesign of the Process Flow. It assumes static speeds for all involved conveyors, so it can calculate when a slug will have cleared other lanes. Stopping releasing slugs would require to update these timings and everything that depends on them. Releasing a slug is also an all-or-nothing type action. I don't actually know what would happen internally if you stopped items of slug that is being released. Most likely they would stay part of the same slug and still count as having been released.
