Custom GUI , Histogram and Line graph
patryk_u2
patryk_u2
[ FlexSim 23.1.4 ]
Is it possible to create a histogram and line graph in Custom GUI? I would like to create a similar histogram and line graph based on the data below
Histogram
arunTTT2P
patryk_u2
I saw this post. How to add a legend to the histogram?
JordanLJohnson
Are you asking for a single chart that shows both the histogram and the line chart? If so, I'm not sure I follow what you want to do. In a histogram, the X axis shows the range of data and the Y axis shows the count of data. in various sub ranges. In your line chart, the X axis shows the number of data points (1 to N) and the Y axis shows the range of data. They aren't really compatible in the same chart for that reason.
But maybe I misunderstand your question. Can you describe more what you would like to do?
Jordan Johnson
Principal Software Engineer
