Custom Flowitem problem : Rotaion, Size, Location
jiseok_y
Message 1 of 8
jiseok_y
[ FlexSim 23.0.0 ]
car size rotation location problem.fsm
After inserting a new Flowitem (Car), when an item comes out of the Source, it should flow to the Sink through the Conveyor, but it is not currently.
I set it as an on exit trigger, but the flow item does not rotate 90 degrees, and the size, position (on the conveyor), and movement are strange. The car comes out somewhere other than on the conveyor
Any help would be appreciated.
Replies (7)
Message 2 of 8
joerg_vogel_HsH
https://answers.flexsim.com/questions/54217/rotation-of-the-flow-item.html
@David.Y please use search tool next time first. I did. First result got this thread by keywords
rotation conveyor item.
Message 3 of 8
moehlmann_fe
As the link Jörg posted shows, a conveyor will reset the orientation of entering items based on the Entry Transfer's setting.
In regards to the weird positioning:
When the car is created it is very large compared to the other objects in the model.
Due to the timing of the OnExit trigger, the location of the car on the conveyor is determined using the old size. When the size changes the object's origin point location stays the same, so its edge is now far away from the conveyor.
To fix this, either adjust the size of the car in the FlowItem Bin, so the created cars have the correct size right away or do the size change in the "OnCreation" trigger of the source (before the location is set).
Message 4 of 8
joerg_vogel_HsH
Also to mention: @David.Y, please prepare flowitems in flowitem bin. And you can use the procedure described in manual to customize objects.
Message 5 of 8
joerg_vogel_HsH
@David.Y another keyword is orientation.
Message 6 of 8
joerg_vogel_HsH
Message 7 of 8
jiseok_y
I thought I had reduced the car size in the flowitem bin enough, but in reality I should have reduced it even more. I understand what you are talking about.
Thanks for your help.
Message 8 of 8
jiseok_y
Trigger timing is important.. I could understand. Thanks for your help.
