Creating items at a certain Model time
rui_c
rui_c
[ FlexSim 19.1.0 ]
envio-de-caixas-por-janela-de-tempo.fsmHello. I'm trying to create items, from a source, for certain time window. I want to close the output at certain model time, and open it again at another. Can you help me?
braydn_t
@Rui C
If I am understanding you correctly, the By Time of Day option allows you to edit a table for arrivals by the time of the day.
Let me know if this is not what you are looking for.
rui_c
Hi Braydn,
Thanks for the reply. I need to put on the simulation the lunch breaks of the factory. I have during the day a normal distribution of Boxes, and I want to block the sources during the breaks.
I've saw your suggestion earlier, but the problem for me is to run the simulation with different source outputs. With this method i need to re-do the whole table.
Regards
braydn_t
@Rui C
I've made an updated version of your model that uses process flow sources to close and open the output of source1. You can use any process flow source you'd like to change the time when work stops. example.fsm
rui_c
Thanks Braydn,
This solutions works well.
Regards
Rui
