Creating a source of operators in FlexSim
Younes
Message 1 of 13
Younes
[ FlexSim 22.0.16 ]
Bonjour, s'il vous plait commenter on peut créer des sources d'opérateurs sur FlexSim (comme dans le cas de Simul8) et ensuite affecter à chaque opération un nombre d'opérateurs avec des compétences précises ? Merci
Hello, please comment, can we create sources of operators on FlexSim (as in the case of Simul8) and then assign to each operation a number of operators with specific skills? Thanks
Replies (12)
Message 2 of 13
allister_wilson
In the majority of cases, you wouldn't choose to create operators dynamically in FlexSim, you would create them all in the model before running the simulation, using model parameters (example) if you want to easily change the number of operators in a given team.
In the few cases where you do really want operators created dynamically, you can use the Man and Woman flowitems (check the Flowitem Bin).
Regarding assigning operators to tasks based on specific skills, there are several ways you could approach that depending on the specifics. Could you attach your model so we can see exactly what you're trying to do?
Message 3 of 13
Younes
pour mon modèle je voudrais faire trois scénarios d'affectation des opérateurs
1 ; selon la ligne 2 : selon l'étape et 3 : affectation complète dans un contexte de deux lignes de production ou je dois simuler ces 3 scénarios
for my model i would like to make three operator assignment scenarios1; according to line 2: according to the step and 3: complete assignment in a context of two production lines where I have to simulate these 3 scenarios
Message 4 of 13
Younes
Message 5 of 13
allister_wilson
Right now in your model I see you have 2 operators, each assigned to transport from one of the sources.
You also have several processors set to call operators for the setup time, but they aren't connected to any operators, and their setup time is zero meaning no operators will be called anyway.
I don't see anything relating to specific operator skills.
Could you please explain in detail exactly what behaviour you are trying to implement, what you have tried, and where you're getting stuck?
Message 6 of 13
Younes
Non c'est juste le modèle basique après je dois affecter a chaque process un operateur mais l'idée c'est d'avoir une sources des opérateurs ou je dois créer des contraintes liées aux différentes types d'affectation d'operateurs
No it's just the basic model after I have to assign an operator to each process but the idea is to have a source of operators where I have to create constraints related to the different types of operator assignment
Message 7 of 13
allister_wilson
Unfortunately this is simply not enough information for me to know how to help you.
I'm still not sure why you want a source to dynamically create operators, and I still don't know how and based on what criteria you intend to select an operator for a given task.
Hopefully someone else will understand what you want and be able to help you.
Message 8 of 13
julie_weller
Hi @Bchiga! Just like how @Allister Wilson said in his first comment, the only way I could think how to do that would be using a dispatcher and parameters. You could set up a dispatcher (or several) in your model and connect an operator and then set up a parameter that goes from 0 to -- (however many you need). That would essentially act as a source of sorts and you could test out the different types of operators. I would check out the tutorials that Allister linked in his first comment as well. You just need to be creative and I think you can find a solution. Good luck!
Message 9 of 13
Younes
Hello everyone, please can someone among you give me all the performance indicators relating to the operators
Bonjout tt le monde, svp quelqu'un parmi vous peut me donner toutes les indicateurs de performance relative aux opérateurs
Message 10 of 13
Younes
In celebration my objective is to create a group of operators where I have to put constraints for the 3 types of qualification ie that the operator must follow the entire production line or two identical positions or a total qualification ie that the operator must perform all the tasks of the two production lines
En fete mon objectif est de créer un groupe des opérateurs ou je dois mettre des contraintes pour les 3 types de qualification cad que l'operateur doit suivre toute la ligne de la production ou bien deux postes identiques ou bien une qualification totale cad que l'opérateur doit effectuer toutes les taches des deux lignes de prod
Message 11 of 13
pierre_gauly
You will find attached a model which might help you (2023_06_20 - Dispatcher example.fsm).
Each processor is S-connected to its own dispatcher, and the operators are connected to the dispatcher(s) of the processor on which they can work.
A "skill" is represented with an A-connection from a dispatcher to an operator.
You can find here (https://docs.flexsim.com/en/23.0/Reference/3DObjects/TaskExecuters/Dispatcher/Dispatcher.html#app) an explanation of the dispatcher.
Message 12 of 13
clair_augsburgerZGWRZ
I advice you to complete the 2 first tutorials on this page:
https://tutoriels.flexsim.fr/22.0/
(Or https://tutoriels.flexsim.fr/23.1/ if you update to the latest release. FlexSim 22.0 is not maintained anymore so I would advice you to upgrade to a newer version).
These 2 tutorials will teach you how to add performance indicators in a dahsboard.
Message 13 of 13
julie_weller
Hi @Bchiga, was one of Pierre G's or Julie Weller's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
