Creating a Custom Table View with bundle data
lcavallero
lcavallero
I followed https://answers.flexsim.com/articles/45747/creating-a-custom-table-view.html to create custom table view.
Every work fine when using treenode table, but doesn't work when table as bundle data.
I tried to adjust the triggers in order to use bundle data correctly, but seem that the table control with style FS_CUSTOM_TABLE_VIEW_DATA_SOURCE doesn't work when the referenced table use bundle data.
Does anyone tried to use with success FS_CUSTOM_TABLE_VIEW_DATA_SOURCE with bundle data table?
Luciano.
JordanLJohnson
The main difference between using a treenode table and using a bundle table is that the getCellNode() callback should never return anything. If you wrote a custom view assuming that each value in the table would have a treenode behind it, then no, that will not work with a bundle.
When you write a Custom Table View, you can usually tell if that view will always point at a bundle or at a treenode table. If you need it to work for both, you will have to write if statements in every callback, handling each case separately.
Jordan Johnson
Principal Software Engineer
