CreateFile failed error
cameron_seams1
cameron_seams1
[ FlexSim 17.1.0 ]
CreateFile failed with error code 00 while trying to connect to the registration pipe.
What causes the error displayed in the picture above?
Any help is much appreciated - I am having model crash issues and am curious if this error code above is the cause for the crash.
Matthew_Gillespie
That message is a debug message meant only for the software developers, but it was accidentally left on in the 17.1 release. If you update to the newest bug fix release that message will go away.
I would post a separate question with more details about your crashing model and we'll help you sort it out. It would help a lot if you posted your model, but if it contains sensitive information make your post private and then only our tech support staff can look at it.
Matthew Gillespie
FlexSim Software Developer
cameron_seams1
Thank you @Matthew Gillespie. If I can't resolve the model crash myself I will reach out - it does contain sensitive info.
