[ FlexSim 16.0.6 ]
Hello, first time on the forum and hoping for some help. I'm new to C++ and flexsim. So far i've stumbled through being able to build my model from the click of a GUI button. The next task is to assign the various parameters/attributes of the objects i've created.
I need to build a Source object, and point that newly created Source to a global table value "GlobalTable20", row 1, column 1, as the interarrival value.
So far i can create the object, but i'm having trouble setting the interarrival value via code once it's been created. Through the GUI, the user selects how many sources he'd like which is why it needs to create the source and point at a global table value all in the same code block.
any help is most appreciated!!! Thanks!
createinstance(node("/Source",library),model());
treenode Source=last(model());
setloc(Source,-70,10,0);
treenode current = ownerobject(c); /***popup:GlobalTableLookup*/ node(">tags/Description",c); /***tag:Description*//**Using Global Lookup Table ( GlobalTable20 )*/ string tablename = /**\nTable: *//***tag:TableName*//**/"GlobalTable20"/**/; int row = /**\nRow: *//***tag:row*//**/1/**/; int col = /**\nColumn: *//***tag:col*//**/1/**/; return gettablenum(tablename, row, col);
