create random number
weiiii
weiiii
[ FlexSim 20.0.10 ]
I want each run to generate a random number from 0 to 1
I tried it in the script first, but the random numbers that came out were all 0
joerg_vogel_HsH
How often did you hit run script button, the green arrow? Once, twice?
And did you open the output console from debug main menu, because there prints the script your result.
moehlmann_fe
To add to this: The number in the Value field is the return value of the code you execute in the script console. You don't return any value so it defaults to 0.
To have the random number show up, use
return numberRandom;
weiiii
謝謝!!我以為打印會直接顯示在那裡
weiiii
謝謝!我嘗試了你的兩種方法,它顯示了
