create objects in different locations in a "for" loop
mohamed_slama
mohamed_slama
smallexample.fsmHi,
In my model, in the OnReset trigger of a plane, I want to find in a table named "tote" if the value is different than 0, then create an object 'tote' for each value different to 0 and set the location of the tote following the corresponding positions in another table named "Locations".
Here is my model, it creates for each non-zero value a tote but it puts them in the same position.
Can someone helps me to resolve this problem ?
Thank you.
Slama
Matthew_Gillespie
Here is an updated version of your model. I changed the code to do what you explained you wanted it to do. I hope that helps!
Matthew Gillespie
FlexSim Software Developer
