Create Label for token using global table containing percentages
vworthingtonFGKPS
vworthingtonFGKPS
[ FlexSim 25.0.1 ]
FederalFactoryModel1.fsm
I am having an issue pulling a label value from a global table. Within my global table named "WaferQuantityPerPO" I have a column containing the percentage of occurrences for 21 different wafer counts. Within the Assign Labels activity in my processflow, I can't figure out the logic to put in value. Currently my token populate with 0 for the WaferQuantity label.
moehlmann_fe
The second column in the table is formatted to contains strings/text (you can tell by the values being aligned to the left edge of the cells). The function returns a number and any string will become 0.
Swap the column to contain numbers and the command will work as expected.
