[ FlexSim 17.0.0 ]
I would like to create a label in a task with the activities of the process flow, but I encountered some problems. I attached a model with my case: I create a task and save in a label "taskSequence" the reference, then with the activity "assign label" I want to add a label in the task sequence but the activity doesn't do that but create a subnode of the task. After some iterations FlexSim crashes.
Is there some error in my model? If I substitute the "assign label" activity with a custom code "set label" everything works.
