create a Global Table in flexscript
enrique.elizaga
Message 1 of 10
enrique.elizaga
[ FlexSim 18.2.2 ]
Is it possible to create new tables inside part of a code. Then to destroy in another code. The number of tables created will depend on an integer in a label called "DAYS TO RUN". I want to have data per day on each table. I tried insertcopy but didn't work.
Replies (9)
Message 2 of 10
joerg_vogel_HsH
Try this
treenode globalTablesNode = model().find("Tools/GlobalTables");
treenode newTable = createcopy(globalTablesNode.first,globalTablesNode,0);
newTable.name = "myNewTable";
It copies the first global table of the global tables.
If you know the name of the table for example "MyKnownTableName"
globalTablesNode.subnodes["MyKnownTableName"]
is the reference to this table object.
Message 3 of 10
SCHamoen
@Enrique Elizaga If I want to do something like this I look through the tree to find how FlexSim did it. In this case there is actually an application command for it:
treenode table = applicationcommand("addglobaltable");
Message 4 of 10
enrique.elizaga
Great @steven.hamoen, it worked! Can you give me more detail on "looking through the tree". This will give me lots of options. For example, when the table is created it opens it up on a new window. How can i close that window through flexscript...
Message 5 of 10
SCHamoen
@Enrique Elizaga
If you open the view tree you can search through the tree in the search box in the quick properties. So I looked for Toolbox and drilled down till I found the table add option
Message 6 of 10
alfredo_df2
After entering the table, how do I assign the dimensions by flexscript?
Message 7 of 10
enrique.elizaga
Hi, do you mean the table size? Doing this.
MyKnownTableName.setSize(5,5);
Or whatever size you want.
Message 8 of 10
alfredo_df2
I cannot do it. This is my script, I want to inser by flexscript a table 38x6, but the software don't read the comand.
Message 9 of 10
enrique.elizaga
@Alfredo DF2 try this instead:
treenode TABLE = applicationcommand("addglobaltable");
TABLE.name = "TravelSX";
Table("TravelSX").setSize(5,5);
Message 10 of 10
manuel_s4
Hi @steven.hamoen,
I searched in the same way as you suggested through the view tree, but I was not able to find which the command closes the window of the new table, can you add it, please?
Thanks.
Manuel.
