Create a Global table automatically, containing some specific token label values
ruben_m4
ruben_m4
[ FlexSim 21.2.2 ]
Hello everybody,
I'm a noob in FlexSim and I don't have much time to improve my FlexSim skills, so I'd like to ask for your help if it's not too much trouble:
Specifically, I would like to automatically create a global table where the column headers would be the name of some specific token labels that I could choose beforehand, and the rows the value of these labels for each token. I would like to create each table entry for all tokens that pass through a particular point in the process flow. I think it is possible to create it using custome code, but I don't really know the flexsim programming language.
I am adding a schematic to explain it graphically:
screenshot-3.pngThank you very much in advance.
moehlmann_fe
There is a pre-made option for this in the custom code activity.
This will add a new row to the table named at the top and paste in the values in the order that the fields appear (First field -> first column, second field -> second column, ...)
You will probably want to choose "Delete All Rows" in the reset option of the global table to start with an empty table each run (the headers will remain).
ruben_m4
ok, thank you so much!
Could I asked you another question?
Now I'm extracting data of times with the command 'Model.time' with which I obtained the number of time until that moment. But is there any command to obtain a date instead a number of minutes or hours (depending of the configuration) , automatically?
moehlmann_fe
Model.dateTime.toString()
returns a string (text) containing the date and time of day.
